i was driving easy today and decide to get on her a little. At a stop sign go into 1st run to bout 6k then second to bout 5k then the car just started shaking as i was shifting to 3rd. When i was in 3rd there was more shaking and no power it was shaking like the rod shifter came loose along with a motor mount. If i let it go under 2k it will miss and chugg like its about to die then eventually does die but as long as i keep it above 2k its fine its stumped me i still have to pull codes and check grounds make sure nothing is lose. Im not sure what might of happen tach still works and just did front 60k, clutch, and rear main. It sounds to me like cps almost or maybe the timing belt jumped a tooth. its not knocking so i don't think i have spun a rod even tho its a major thing on my list 177,000 and probably original bearings. I dont know what to do any help would be appreciated!!!!
Makes sense that yall aren't as far away as Winchester since you come in town to CAP.
