Speedometer Problems
amtrakmatt
Orange County
Has anyone had problems with the speedometer not wanting to pass the 125MPH mark. I was trying to catch up to a BMW 540, once I hit around 125MPH it started bouncing up and down. I thought it was go to 140MPH.
multishowner
Grovetown, Georgia
mine does it at about 110... it bounces for a few, then drops to zero... the good is that you should never hit the factory electronic speed limit because it uses this input from the system... the bad is you won't know how fast you are going when the police pull in behind you...
Cheers!!
amtrakmatt
Orange County
Thanks for the info guys. Yes, it's a 1998, I'm guessing that problem isn't worth fixing, since it's not too often we're going over 120 mph. I had my 98 SHO welding about a month after buying. John Stossel in Los Angeles did a great job welding it. Also replaced all coils after several failures.
Matt
Orange County
The cure is though to be a non-'98 ABS controller although it is just theory....
It was the PCM that was eliminated. I don't know of anyone who has replaced the ABS controller on a '98 with some other year to cure the speedo problem.
98SF19
AlphaKennyBuddy
Florida
update?
I happened to be researching speedo and/or tach signal problems and found this thread. It's over 5 years old, so is there anything new on the non-ABS controller curing the 98 high end speedo problem?
Thanks!
roland
Volvo fanatic
Chengdu
problem was the 98 SHO can't catch a 540i.
I didn't know the 98's have this problem, I'm going to look at one tomorrow so that's a good thing to know......
stephen newberg
Ladysmith, BC, Canada
I think the track on the South Shore of Nova Scotia is about 50 meters or so above sea level. Might be a bit more, but its certainly not very high. Both the car and I were younger then, too. Quite a bit younger, actually... :)
pax, smn
98SF19
AlphaKennyBuddy
Florida
Soooooo . . .
Stephen and Paul, so you've both defeated the speedo problem (not sure if Paul owns a 98)? Does this mean that you've installed a non-98 ABS controller? I very much doubt that I'll ever take my '98 over 100mph or so (by choice), but in the event that I sell her, it'll likely be to someone already familiar with the issue, and I'd rather not get into the whole argument of the cost of a non-98 unit and the labor needed to install it vs. the difference in the offer.
stephen newberg
Mine is not fixed, the speed and time runs were done at a track and speeds radar indicated.
Though Paul suggested a possible fix some time ago, I have not heard of anyone having tried it.
pax, smn
