Speedo Problems
NJSHO
Clean Your Shorts!
NJ
Since Ive had my car, the speedo needle has shook. I finally decided to replace the upper speedo cable and that solved the shaking. I then saw that my speedo was about 10mph off from what it should be. I recalibrated it by driving on the highway and taking the needle off and placing it on 60mph when I was traveling @ 1 mi per min. All seemed well until it got cold. Since then it sometimes would read correctly, sometimes not. I left the plastic cover that goes over the gauges off, and when the speedo wasnt reading correctly I could just tap it to the right speed and it would stay reading the right speed for some indeterminate amt. of time. After getting fed up with doing that, I went ahead and replaced the lower speedo cable. Now my speedo is back to shaking, but only at speeds above 50 mph. At this point I am thinking that I might need a new speedo head or that the cable is routed funny. Any body have any ideas?
It sounds as if the speedometer needle's bearings may be sticking. With the head out of the dash, use a lightweight machine oil to lubricate the needle bearings on the indicator needle's shaft.
NJSHO
Clean Your Shorts!
NJ
How do I get to the needle bearing once the head is out of the dash?
SHO_Driver
Montreal, QC
Should be able to spray it from the back. It stopped the sqeaking noises I was getting and the shaking. I removed the whole speedo and sprayed some on the front too, hard to clean that oil from the face tho.
