Speed Hut gauges
puddnlovr
pennsylvania
Hello my fellow Americans.I am in the process of installing Speedhuts in my 94 atx.I can`t seem to get the needles to stay where I want them.My gas is at 3/8s full and it keeps going to full.Also,My car idles at 800 RPM,but it stays at 500. any suggestions?
droptSHO
Wheaton, IL
Did you pull your needles off when you installed the speedhuts? Because there was no need to. Just work around them and the needles will go back to normal. But if you pulled them off, I think you just have to play around with them until they are right. Go to a big open parking lot or something and have someone drive next to you so you can set your needles correctly....well, atleast for the speedo.
puddnlovr
pennsylvania
I did pull the needles off prior to installing the gauges.The directions told me to.I'll go play with them and see what happens.thanks!
