Speaking of trunks
362104
DV8
43*46'30"N 88*26'41"W
My interior trunk lever pulls up but nothing happens. Could it be stripped or the cable broken. What typically causes this? 93 ATX with 143K. I am sure age has nothing to do with it:nut:
Chip
TimboSHO
Intermediate
Wyoming, MI
Hey 'Chip' :)
The trunk lever actually works(unlatches the rear latch), the trunk just doesn't 'pop' up. I know there were three tention adjustment on the trunk in my Gen 1, and by moving it up a notch, it would cause the trunk to 'spring' more when you pull the lever. That's one thing I always meant to look at on that car, but never got around to....
sperold
Last to Know
The weight of the spoiler keeps the trunk from flying up, like in a regular Taurus sedan. Maybe the spoiler cars from the factory had stronger torsion springs in the trunk.
SHOmethewayhome
BAD ROLE MODEL
Saint Paul, Minnesota
no, my car had a wing before it broke off and when i popped the trunk it would just unlatch and barely lift, now with the wing off it flies open.
joesho_gb
95 ATX
WI
Try looking on the latch, inside the trunk. The cable may have just come off. You might need a socket to get it off, just two bolts. Before you take it off, mark the position that it was in with a black sharpie, so you get it aligned correctly when you put it back on.
You should be able to see a black tube running to the side (passenger side) of the lock. The wire is in there.
If it's broken, you should be able to get a new wire from Walley's Pick & Pull there in Oshkosh. They have a TON of 92-95 Taurus' there, and I do know they have a black Gen 2, ATX there as well.
