First of all, it's a 94 ATX. I rinsed off the engine yesterday, and of course I had water in the plug wells, even though I was careful. It's probably some of the plugs are fouled. Would this also cause the wires to go bad? It starts fine and if I slowly increase the throttle all the way up until I hit the rev limiter, it's fine. But if I goose the throttle at all it'll start to sputter. So my question is how to test the wires to see if they're bad and are there any plugs and wires that I can get locally that will function until I can get a hold of the ford ones. I think I remember reading that a set for the MTX will work on the ATX they're just a little bit longer, correct?
<small>[ September 29, 2002, 01:01 PM: Message edited by: CENC-SHO ]</small>
