Sound system
marbs
Roy/Ogden, Utah
I threw in my two 10" subs in the trunk of my 94 PREMIUM SOUND and I can't even hear them when they hit. They are wired the same as they where in my LeBaron Convertable. I was wondering if ANYone knew what I could have done wrong. ALSO my friend and I are TRYING to wire up a CD player in his 90 Mustang GT 5.0 with the premium sound and the only way you can hear music if it's turned up full blast then It's like being played on volume 1. Does any one know what we could have done wrong their? It works PERFECTLY in his 90 LX.
slickn56
North Attleboro, MA
Your two 10 inch subs are most likely blown. Just kidding. You have an error in your wiring and you wired one subwoofer out of phase from the other. Try switching the wires around and see what happens.
shadow102
Atlanta, GA
yeah just make sure they are getting power and all the connections are completly connected...btw what kind of subs and amp are you running??
marbs
Roy/Ogden, Utah
The Subs are "Q Power" 600 watss. The amp is a 560 watt "Jensen". All the wires are hooked up correctly. We've quadrupled checked. :confused:
marbs
Roy/Ogden, Utah
Should I just throw some 8in. Subs in place of the rear speakers? If so do I need to keep the amp that's powering the ones I've got or should the factory Amp. be enough to power them?
