something weird just started
duckrider
ohio
so i just got my red95mtx back on the road after strut change and i am driving it down the road to check out the alignment and make sure every thing is ok..... and my car starts surging... like the secondaries are kicking in and out...? i can even hear the sucking noise but it is happening at idle and all rpms...? this is the first i have driven it in about four weeks, i am going to go run the codes and see what i get, .... any ideas on this one...?
duckrider
ohio
what is the CCRM....? cruze control relay mod...? or something like that...and is the fuel pressure suppose to be with in a certain range..?
duckrider
ohio
well ran the codes and nothing useful just that my coolant temp sensor was out of range.... time for more investigation
93_blk_blk_mtx
Springfield, MO
The CCRM is the black box underneath the radiator panel (big Ford decals). It controls the fuel pump, a/c fans, etc. This is known to short out causing fuel pump issues. I've had a similar problem with my 93 SHO, where at certain times the car would buckle and shutter and shake violently. I ended up swapping out my starter (which soon eventually failed), fuel pump (stopped priming) and IRCM (code 543, 556 came up).
Redline
Fire It Up
Sandpoint
I get a similar surging whenever my defrost or ac is on. I think its my ac compressor.
