Somebody lying
Shokev
Philadephia
Went to the dealership today and they said the ptu fluid and the read diff fluid aren’t serviceable??????
4sfed
Either that, or they didn't want to do it. Either way.... You're better off going somewhere else.
Shokev
Philadephia
Should i go to another dealership or take it to another shop like good year ?
Csbbrah
Ky
Dealerships for the most part still cling to that lifetime fluid bs. No ford dealers around would touch it. Had to do it myself. Wasnt too hard.
Sent from my LM-Q610(FGN) using Tapatalk
Shokev
Philadephia
Is there any vids on on that you know of it probably isn’t that hard but i just want to make sure about it
Csbbrah
Ky
Jordan_R
Missouri
Dealerships look up the change internal and it says lifetime. That's what they are looking at. Although we know better than that... I guess it would be lifetime assuming the ptu has exploded otherwise.
gwrabbit
Wisconsin
In my experience, dealerships have always been trash when it comes to these things.
You're far better off finding a shop you can trust.
Shokev
Philadephia
Does anyone know if the non pp 2013 shos have a drain plug on the ptu ?
Csbbrah
Ky
They have a fill plug. Will have to suck out old fluid with pump.
BobDozer
Austin, Texas
Rear diff is pretty easy. Changed mine two days ago but it really was not that bad looking as far as the fluid.
Sent from my SM-N960U using Tapatalk
Shokev
Philadephia
Did you take the whole cover off or got it out with a pump
Take the cover off, and get all of the shavings and crap out of the bottom. Then refill with Redline Shockproof Lightweight Oil. If you do the PTU, use the same oil.
BobDozer
Austin, Texas
Taking the cover off is the best way but I pumped it out about 32 ounces then put some royal purple. Changed the PTU fluid at the same time so in about 15k I'll change both again but rear cover is coming off.
Shokev
Philadephia
What’s the part number for the rear diff gasket?
Christian
Chilliwack BC CANADA
I guess I'm lucky. My local Ford dealership fully embraces fluid changes in all components. They did my PTU and will later do my trans and RDU. When they did my PTU, they also discovered a leaking CAC and repaired it. I'm impressed with them so far (Chilliwack Ford).
