Some help again please :)
bcdescd22
Louisville,KY
OK this car has had the following replaced! IAC,CID,CPS New plugs n wires new fuel filter new air filter cleaned the MAF sensor and new TPS. The gas milage was fine last time I filled up the car I got about 300 miles and I put prem in it. But gas went back up had to put reg back in it put about 8 gal in her went about 100 miles and she is back on empty :cry: Only thing I notice with the car is sometimes it surges when you first start it but when it heats up its fine. The transmission has been acting funny long delays in changing gears sometimes. But when I was turning a corner I gave it gas going around 20-25 and seemed like the rpms went up and then it went into a low gear then I gave it more gas and it went into the other gear very quick. Right now the car is getting the transy fluid replaced. And today I was crusing on the interstate and it did seem slugish with the a.c on. SO the car is a 94 with 115K on it I havnt changed the o2 sensor's yet but theres no codes in the computer. Should I change thoes? And Im guessing is it a time to save up for a transmission rebuild?
1stSHO
Asian Lover
Fort Walton Beach,FL
I would change the 02's. You did everything else.
Sounds like the tranny is starting to fail. If you get it rebuit have them put a good external tranny cooler on it. It helps it live a long life.
Good luck :thumb:
