Bluezone
Ont, Canada
looks like all your free time just fell out of view.
I don't think I like the Timbre of your voice. Lol
Wood I, could I do things differently, yes.
But I beleaf things should left unsaid and not branch off into speculation.
I will stay rooted in my convictions.
Zpak
Es Aich Oh!
The region, Indiana
At least he’s staying grounded and can see the barn through the trees. Now you have the opportunity to branch out into new endeavors.
Kevin81
USA
You guys are cold as ice!
It's OK, though. He can take it. He's got strong roots. Thick skin, like bark.
GotGrip?
Conversation Ruiner
Minnesota
Sourced out turbo blankets with a company in the UK called Funk performance. According to their sale rep https://funkmotorsport.com/product/mk3-turbo-blanket/ t25 blanket will fit our turbos. I'll probably be buying a set myself once I recover from my maintenance bill for timing and turbos.
EDIT: I did send pics and measurements via email to confirm size/fit.
Joel Munoz
San Antonio
What did I do to my SHO today? I had a professional installed my GearHead intercooler today and I loaded my revision GearHead AO 93 tune. I want to know if anyone has a GH tune with their intercooler, what do you have as your idle rpm? Mine is showing at 600 rpm after I loaded the tune.
Lowrider1976
Grandma's grocerie getter
New England
Yep 600rpm here. Seems to be the default, but that's able to be adjusted as well
Ta2dResqr
Central Ohio
20210925 12155020210925 16211420210925 210347EPP Hot Pipes, EPP Intake, GH Intercooler, Osram Xenarc Laser Headlights, LED Marker, Drive Bright "Fog" lights, Drive Bright Puddle lights, Sync 3 conversion, all speakers switched to Infinity Kappa, sunroof Visor, and some general cleanup.
Joel Munoz
San Antonio
I went along and pull the trigger today. I order my PPE downpipes and Corsa CatBack Exhaust thru Ortiz Performance. Currently I'm running a 3 BAR Map sensor, Pre-Gapped Spark Plugs, 170 degree thermostat, K&N Drop In Filter and GH Intercooler & AO 93 Tune. Is anybody running these set up with an Ortiz Tune and if so which level are you running?
Bluezone
Ont, Canada
I went out to shannonville today for the mix and match. I did about a dozen laps at the road course. Handling was really nice. I was even hanging in there with a Miata who wasn't trying too hard.
At the drag strip I tried different launch techniques and tire pressures. I'm still traction Limited. My personal best ET today with not too bad of a trap speed. This was achieved with an easy lunch and 37 PSI in the tires. I guess the Continentals like more pressure than less. So I'm officially in the 12s barely.
12.959 @ 108.84 miles per hour.
Lowrider1976
New England
At what rpm did you adjusted too and did you adjust the rpm using the tuner?
I've left it as it is for now. Once I get the rest of my installation done then if it's still a little rough then I'll adjust. I feel like the ppe downpipes may even it out some, but I may be wrong.
Lowrider1976
New England
Congrats on the personal best! What size continental tires do you have?
Ashleycat
