Usmcsho01
- Joined
- Oct 9, 2016
- Messages
- 139
- Reaction score
- 202
Those wheels are sweet!
Negative, wish they did... It would help with the ice..Do they allow chains where you are, StealBlue?
What software are you using, first of all? Torque Pro or Forscan Lite? You should get 4 sensor readings off of either one, but you need to pick the right O2 (air/fuel) sensors also. Torque Pro has PIDs for wideband sensors (front O2s) so use Bank 1 Sensor 1 and Bank 2 Sensor 1 for those. Try O2 Sensor1 wide-range voltage and O2 Sensor 2 wide-range voltage see what you get. If those do not work, try O2 Volts Bank 1 Sensor 1 and O2 Volts Bank 2 Sensor 1. For the rear O2s (regular narrowband), use the regular O2 Volts Bank 1 Sensor 2 and O2 Volts Bank 2 Sensor 2 PIDs (further down the list of PIDs).
As far as boost, it's supposed to vary depending upon load/throttle conditions, but I'd not worry about that just yet.
