DadMobile
Texas
Insurance & lawyer’s are the real fun governors.
My local track is pretty tame for the most part. They have never checked my helmet. They only seem to care about your battery tie down and they check for leaks. If you have nitrous they require an engine diaper. You only need a roll cage if your car is 6 years old and runs faster than a 10.5 or something.
stripSHO
Idiot Savant
Detroit
Kind of a weird flex @stripSHO. All that ^^^ bc you “used to be” a track tech? I didn’t feel like I got a free pass either...felt like I encountered a decent person. Like I said in my particular case it’s not needed. Glad them boys @NED don’t let their title of Track Tech go to their head. Some real good dudes
Not a flex at all dude. Just speaking from experience that when a tech guy says you need something and lets you roll anyway, and then you show up the next time without said thing, it's a huge double middle finger and a loud & clear sign of no respect, and a sure way to fast track yourself onto their shitlist. Take it under consideration or don't. I don't really care what you do. Thought you might appreciate the insight but clearly you don't since you for some reason feel compelled to be a snide ******* about it. (I'm just treating you accordingly, as you say. Don't take it to seriously :tongue:)
BTW, straight from NED's racer handbook. Surely you're so familiar with tech inspection that you've already committed this to memory, but I'm listing it here for the rest of us that ain't so learnt-
Elapsed Time (ET) of 10.00 - 11.49
• Snell 2010 (or newer) helmet
• Fire Jacket meeting SFI 3.2A/1 Specification
• Hood, optional. Carburetors must be covered by flash shield or scoop
• Radiator overflow can.
Seat belts meeting SFI Specification 16.1 or 16.5 within 2 years expiration from date of manufacture.
Drive shaft loop
• Battery hold-down
• Harmonic Balancer meeting SFI 18.1 Specification (10.99 or quicker)
• Properly secured fire extinguisher recommended
• Aftermarket axles and axle retention devices (10.99 or quicker)
• Roll Bar, except on Showroom Factory Stock street driven hardtop cars and trucks 2008 and newer. (9.99 or 135 MPH and slower)
• Convertibles, T-Tops and any car with modifications must comply with 11.49 rule, 13.49 for convertibles.
• Window Net (vehicles equipped with a Roll Cage only)
• Transmission shield/blanket meeting SFI Specification 4.1.
• Neutral safety switch mandatory for all vehicles with an automatic transmission. Reverse lockout mandatory. If a manual transmission vehicle was originally provided by the manufacturer with a clutch interlock switch it must remain operational.
• Flywheel and clutch meeting SFI Spec 1.1 or 1.2 (2 disk maximum) or cars powered by rotary engines 13.49 or quicker.
• Flywheel shield meeting SFI Spec 6.1, 6.2, 6.3, or 9.1 required on all cars using a clutch. Cars with rotary engines running 11.49 or quicker must be equipped with a flywheel shield made of ¼ inch minimum-thickness steel plate surrounding the bellhousing 360 degrees extending 1 inch forward and 1-inch rearward of the rotating clutch assembly; shield may not be notched or cut in any way. Shield must be securely attached to frame or frame structure, may be multi-piece. All rotary engine vehicles equipped with nitrous-oxide injection and/or turbo/supercharger running 9.99 or quicker or 135 mph must use a flywheel shield labeled as meeting SFI Spec 6.1 or 9.1 minimum. Cars for which an SFI Spec 6.1, 6.2, 6.3, or 9.1 flywheel shield is not available may use an SFI flywheel shield from another application bolted to a motor plate that is bolted to the engine at all available bolt holes. See NHRA General Regulations 2:3, 2:5, 2:6, 2: 10.
• All vehicles running 10.99 or quicker must use a lower engine oil retention device.
• Arm Restraints required on all open bodied cars
• Metal screw-in valve stems unless OEM tire pressure monitor sensor is used.
• Check current NHRA Rule Book for additional requirements and specifications.
So yeah, like I said, they've been giving you free passes. It has nothing to do with the seat, though I'm sure they could nail you for the seat itself too since it may not be properly installed per manufacturer's instructions (no rear mount).
802SHO
Boost > VE, MBT, Cams
Essex Junction Vermont
Drive shaft loop
• Battery hold-down
You weren’t there. You don’t know the full conversation and you don’t know anyone involved except me. I don’t care if you would be a tech busting my balls. You’re not. You used to be one of those guys, you’re not anymore, time to move on. Appreciate your concerns.
BweegN
Springfield, VT
Happy Easter Fam. Just wanted to take a moment and say thanks.
I am a pretty knowledgeable car guy and I am confident in doing anything that is thrown at me. That said, there is a lot of shit going on in these cars and I have a lot of questions because for one thing I can't afford to fix it a second time and another thing is there some parts of it I just don't understand versus a good old classic car.
So, I just wanted to say thank you for a great forum of people and not once through any of my stupid questions has someone said to use the search button and that is a rare find in a forum.
Yeah buddy!
In relation to the Post I finished polishing my exhaust ports and will be putting my heads back together so I can drop them off to CNCwerks to be checked out. Still waiting on my Gen2 crank :-/
Sent from my SM-G988U1 using Tapatalk
Roman
Mi
Yeah buddy!
Happy Easter brother!
DadMobile
Texas
Yeah buddy!
Your build is coming along quickly!! Happy Easter :)
Sent from my iPhone using Tapatalk Pro
Wsho
Sacramento California
So I took my dash all apart strippers all the pieces took them into vinyl shop and they wanted $400 the wrap 7 pieces. I wish @Nova live closer I'd have him do all my stuff LOL. So I ordered all the stuff today and should be here in about a week. Once again do it yourself .
Need to get everything done and assembly in the next 2 weeks before my carbon fiber steering wheel and shifter comes in.
IMG 1914
Joshw0000
North Carolina
If you want it done right (and not *****), do it yourself. You'll be happier with the end result and have some jingle in the pocket when it's said and done. Looking forward to seeing it.
Sent from my SM-N960U using Tapatalk
802SHO
You can also buy an overlay kit. https://directcartrim.com/products/2010-taurus-real-carbon-fiber-dash-trim-kit
Nova
US
Damn! That's crazy, if they are charging that much maybe I should start doing this as a side job lol. You'll enjoy the satisfaction of doing it yourself and then you'll want to wrap more things on your car, ask me how I know lol. I always wipe down the pieces I'm going to wrap with isopropyl alcohol to make sure there are no grease or oil residue and I also clean my fingertips with the alcohol as well to get rid of the oil from them as well.
Caleb Scott
New York
I have been reading through this thread for a while and thought I'd share my recent experience.
About a month ago I got into an accident. A guy in a nissan rogue t-boned my sho(2018 PP, black, GH tune-93 oct, CAI, JLT catch can, 170 T-stat, plugs, and SCT livewire) at the driver/rear door while coming around a corner on fresh snow. Shook me pretty good and I could barely open the door because the hinges were messed up. I was going away the day after this happened so the car sat for a week before I could take it to the body shop.
Got it in to the body shop and got a quote back for over $15k worth of damage(included some pictures below of damage and after). Although the police report had a diagram of what happened in the accident, the other driver's statement (which was a lie) the officer said he had to include. His insurance company therefore said the evidence was inconclusive and they weren't accepting liability. I ended up going through my insurance so they could fight the battle and get reimbursed.
After around 3 weeks of driving a bone stock charger(which was terrible to drive) I finally got my car back. Everything seems to be working well on it and I'm very glad I have it back. I just did a chrome delete and would like to get new wheels and possibly wider tires soon.
Sorry for the long story. Thanks for reading
DadMobile
Texas
Man that sucks. Glad you got the car back though! I almost surprised they didn’t total it out.
Caleb Scott
New York
I was surprised/glad as well. I only have 20k miles on it so I'm assuming that's why.
I also installed a vava front and rear dash cam so I can have evidence if there ever is a next time(hopefully not). One thing to note if anyone gets a vava dash is to format the mini sd or else the loop feature won't work and the card will fill up and stop recording.
part 3-13(pg 6) of this. https://image.vava.com/media/downloads/VA-CD001 APP V1.3.3 Detailed Guide.pdf
Wsho
That would be a good little side job especially if you like doing that. It was $300 for 4 hours of Labor and they said the materials come to another $100.
I ordered Black carbon fiber gloss and carbon fiber White and a pack of 5 glue pens. I should be good to go i hate driving the car around town with the dash all tore out.
Nova
US
Wow! 4 hours of labor?? Thats probably double of what it should take an experienced person to actually do it. Oh make sure you have a heat gun to help with the stretching, since you're doing carbon fiber vinyl don't stretch it too much or else you're going to have spots on the carbon fiber design that's distorted and won't match the rest.
Ashleycat
