802SHO
Boost > VE, MBT, Cams
Essex Junction Vermont
So, car is on stands, most of my stuff came in. I'm doing the springs and shocks first. Will post pics when I'm all done. Still waiting on the noisemaker delete, and the darn down pipes, but I'm done waiting. Car will be on stands all week. Gotta do the suspension, drop the old DPs, drill and tape the PTU, change rear gear oil again, install the UPR catch can, new plugs, new T stat. Then start working on the gear head tune. Been so busy with work, I haven't emailed gear head back with the current tuning strategy...they've been asking for almost 2 weeks now, lol.
Question...does the rear gear housing take any sort of limited slip additive?
I put Redline Received 768476943906600 LightWeight Shockproof gear oil in both PTU and RDU...then it's easy don't need two different kinds
Yep Redline LWSP in my rear diff and PTU as well. Highly recommended.
Ryan Selcer
Colorado
Redline LWSP only comes in one viscosity. Yes. We put the same viscosity in the PTU and RDU.
That seems like bad news to me... the viscosities are WAY off, either its too thin for your ptu or its too thick for your diff, im guessing to thin so your saving yourself by changing it every 10k
Neither. Numerous SHO owners took the direct recommendation from Shodded including myself.
https://www.redlineoil.com/lightweight-shockproof
Read about it and you will understand why it works for both the PTU and RDU. I have over 8k miles on LWSP in my RDU and PTU. The bulk of those miles are at 90 mph on the freeway in 100+ degrees weather driving from Phoenix to the Cali.
The stuff works great. Significant difference how smooth the car is compared to how it was.
I do change the PTU every 10k miles. So after my trip to CA in September it will be changed. I will drill and tap the case as well.
I change the RDU every 30k miles.
Ryan Selcer
Colorado
I've seen test after test by multiple people in which Amsoil consistently outperforms Redline on multiple lines of oil. Now i havent been able to find a comparison between severe gear and shockproof, but it seems to be a pretty even 50/50 split to which is better based on peoples opinions. But, from my research due to the suspended particles in the shockproof it will help tighten up old worn out gears, and the Amsoil will provide better overall protection.
You can run what you would like. I have nothing against Amsoil. I just know the most run hard and abused SHO's run Redline LWSP in both RDU and PTU's. All the owners have reported they love the performance of Redline and how smooth the drivetrain is. Also zero failures as well.
Remember these are real world tests, with numerous dyno pulls, and numerous tracks runs in our platform, not another one.
Ryan Selcer
Colorado
You can run what you would like. I am nothing against Amsoil. I just know the most run hard and abused SHO's run Redline LWSP in both RDU and PTU's. All the owners have reported they love the performance of Redline and how smooth the drivetrain is. Also zero failures as well.
Remember these real world tests and runs where in our platform, not another one.
Well i don't see you guys giving any real comparison. Youre just saying its better than the old burnt out stock fluid....of course it is
Ryan Selcer
Colorado
I'm all for using whatever is best based on actual tests and comparisons. But from what I've seen the people using the shockproof have only compared it to the old oem fluid they are replacing and most of yall haven't used it more than 20 or 30k miles so you really have no leg to stand on for reliability claims
Ryan Selcer
Colorado
I back amsoil because its been around forever, the vast majority of racing teams use it, and time and time again i see it beat all the other top brands in nearly every test.
Ryan Selcer
Colorado
Royal purple matey! Yarrrr be good stuff @ reasonable price and no buttgames with a guy in a shed to buy it(amsoil)
Lol I dont have to do any butt stuff, but ********* Gandalf takes FOREVER hed like 94 and it takes him 30 minutes to hand write your receipt lol. Oh well, worth the wait. I pay 8 a qt for my 5w-30 and 17 a qt for my gear oils. Oh and the ATF is only 13 a quart, I do have to go to another city. But its on my way up to my dads place in the mountains so I just stop by. I will admit that much, amsoil can be hard to find or expensive
I laid my case. There are zero Redline PTU RDU cars have failed so far. They have also held up in OUR platform in the two fastest SHO's. Also I thrash the **** out of my car in extreme heat. Either on dyno pulls, street light grand prix run, drag strip, or fast prolonged deserts runs at 90+ mph in 100 to 115 degree weather. I would venture to say my SHO is right up there with the most "spirited" drive SHO's.
Also the gentlemen (SHOdded) that gave us the lead on Redline LWSP gave us good reason too. He didnt compared it to the burnt fluid. The main thing is you want is an ester based fluid for heat. It also gives amazing shock protection. He also gives Amsoil a high rating as well. Also Redline is shipped directly to my house from Amazon, same day.
Michigan-SHO
Michigan
I appreciate real world results in a specific application.
Michigan-SHO
Michigan
However, since my vehicle is in the shop, this is what I use right now for my rear end. Keeps everything well lubricated.
beesbuild
