So i was trying to pull down my rod shifter assembly...
syP
GTP>SHO>*.cars
Wheaton, Illinois
Since my shifter boss needed to be welded since it broke in this thread http://www.shoforum.com/showthread.php?t=92489
I tried to lower the whole assembly and i noticed
Someone welded a plate to the frame. Damnit.
I went without this car for 1 year and so much shit is changed/messed up :cry:
What do i do now? Cut it off (somehow) do what i need to do with the shifter, then re-weld it up there like that?
stangeater
Farm Boy
1. Light torch
2. Cut Plate
3. do whatever
4. Weld back in place
Too bad you weren't closer, I'd do it for you.
Jeff
syP
GTP>SHO>*.cars
Wheaton, Illinois
i have no problem doing it.
but im making sure that this ISNT stock right? the "stock" location of the support is where the shifter boss connects to the trans? (its clearly cracked/broke on mine) so i think when the last owner (who went through 3 clutches in 1 year :( ) had the clutches installed, they found that and welded it up there.
Racer X
SHO Pilot, Retired
Connecticut
:eek:
That is NOT supposed to be like that.
That is also why your stabilizer boss is borked like it is.
Get that plate out of there, repair the boss, and never do that again.
Wow, just when you think you've seen it all...
93rev2sev
Hockeytown
I agree with racerx cut that "bracket" away from the real car parts and throw it away.
syP
GTP>SHO>*.cars
Wheaton, Illinois
When i sold this car a year ago..... there was a ****** there...
my beutiful Y-pipe... :(
i should strangle the last owner for how much he ****** up my good condition 95.
newby92
3.2 swapped 95
ohio
yeah welding that is a very bad idea, it has to be able to move with the motor and trans when it torques forward and backwards, by welding it solid to the body when the engine torqued it prolly ripped the mounting boss right off the tranny. DUMB idea...
