So I changed my TPS last night.
SilverSHO
cartersville
Car was bucking VERY hard under light throttle...like, I would step on the pedal and it would lose power for a second or two, then THUMP! as the engine regained power and bounced off the hood, causing the whole car to lurch back and forth. The CE light was flashing on and off as well, so I checked the codes and found that the TPS was bad. Stopped at Autozone last night and picked one up (Wells TPS215, $23.99), and now she runs like a top again. Throttle input is silky smooooth now; no more lurching and bucking between gears. thumb
Blue-By-U
CT
Ishodu:
It feels great when your effort pays off uh?? thumb
It also feels good when the cheapest and most easy to install sensor for your car is the solution to your problem thumb
revhardSHO
Seattle, WA
Blue-By-U:
Ishodu:
The two philips-head bolts that hold it in place were completly corroded. Took me about 45 minutes to remove the dang thing! :mad:
<small>[ November 02, 2003, 11:34 AM: Message edited by: smithsil ]</small>
Blue-By-U
CT
So how did you eventually get those screws out?
I bought a new TPS on ebay for a great price and wanted to replace my stocker which had 100k just for preventative maintenance. I actually had problems with those two screws also but I was unable to remove them since they were almost stripped.
AutoSHO
No SHO = Mo $$$
Fort Collins, CO
I've found the easiest way is a pair of pliers gripping the outside of the screws. Or cutting a slot through the heads with a hacksaw.
rangerj
Brunswick, Ohio
Did you apply a thin coat of anti-sieze compound to the threads of the screws when you put them back in? This helps to prevent the screws from getting corroded and becoming stuck in the throttle body aluminum casting.
rangerj
revhardSHO
Seattle, WA
AutoSHO:
pliers eventually got them both free.
