So How Bout This Problem......
89CanadianSHO
Beaumont,AB, Canada
I got in my car yesterday and began to drive, about 30 seconds away from the house I realized I had only 1 big gear 2nd; the one it was in. I turned the car off and tried again, and I still only have 2nd gear. I can shift to where 1st is supposed to be, without the clutch depressed. I have no way of getting it into any other gear. And it's like there is a big void where 1st and neutral is. So any ideas??? I have already checked the shifter and it isn't broken....And I have checked the shift linkage and it's fine too. So any thoughts??? I'm thinking syncros maybe???? Please Help!!
masho95
got Zex?
Chicopee, MA
What year SHO? I'm assuming an earlier year SHO with a cable shifter. If you checked out the linkage below the car, don't forget to check linkage connections below the shifter boot. Those cable connections can also pop off. A big "void" is most likely a disconnected cable linkage issue.
89CanadianSHO
Beaumont,AB, Canada
K, So now I have found the problem, The under the car shift lenkage is screwed...I must of missed it the first time...so now i need the little rubber grommet because i need to replace it...so if anyone has anything that sounds like it could you please email me at [email protected]
89CanadianSHO
Beaumont,AB, Canada
K, So now I have found the problem, The under the car shift linkage is screwed...I must of missed it the first time...so now i need the little rubber grommet because i need to replace it...the grommet goes on the coupler that links the linkage from the tranny to the linkage from the shifter...so on the shifter end there is a little grommet and FORD has it listed as obsolete...mind you I don't think the parts guys knew what i was talking about...since this part is so small and so hard too explain...so if anyone has anything that sounds like it could you please email me at [email protected] or I could send you a pic of what i need...I don't know how to post them on the forum....
masho95
got Zex?
Chicopee, MA
Even better than spending money on that. Put the shift cable connector where it's supposed to go, and take some wire (semi-heavy gauge maybe 19 AWG or lower) and wrap the connector up a few times so it won't come off. Did this on my buddies 89 SHO and after MANY hard shifts the linkage is still intact. Beats spending money on a part that is bound to break down the road. Just make sure it's wrapped tight. If this doesn't sound good, I believe that there is a MOPAR part available that might work. Do a search for it and you should be able to find it. Good luck.
Yamaha V6
SHO Enthusiast
Rhode Island
Josh T once recommended to me to use a small cross-section of power steering hose, etc., to replace the blown out bushing. Helps tighten up the shifting a little. Then tie-wrap it in place.
Also, get a rod shifter if possible. :)
SHO_Driver
Montreal, QC
Yamaha V6:
Is there anything he doesn't know?!? He showed me how to make one out of PVC pipe. Fit perfectly!
