Some things to think about when it comes to hauling or towing. This is from the research that I have done. I am not new to hauling, I am new to these type of weights.
I will try my best to break down the weights that I have researched because that will play a role later with DOT standards and Insurance coverage.
Prelim weight numbers are the looking like this:
2000 F450 GVWR: 15,000 lbs
F450 Cab and Chassis : 6789 lbs
Utility Bed: 1200 lbs (rough guess-imate)
Other Weight: People, Tools ect: 700 ish lbs
Total Truck weight: 9000 ish lbs
2016 Lance 1062 Camper Wet Weight: 3900 lbs
Add other things pots pans ect: 250 lbs
Total Weight 4150 ish lbs
Total Weight of Truck and Camper: 13,150 ish lbs. Well below the 15,000 lbs GVWR limit.
I will 100% verify this weight the same day I take delivery with a full tank of fuel.
I do plan on hauling a car trailer with various different cars behind the truck and camper as well. However I have limitations there as well.
My truck has an attached Torklift SuperHitch Extension System. Now if that is mated to a regular aftermarket hitch my towing capacity is only 6,000 lbs. If it is mated with the Magnum Receiver Hitch, that bumps it up to 10,000 lbs. I will have to check when I pick it up.
Looking at Carson California Car Haulers. My buddy has had one for 20 years and he swears by them. GVWR of the trailer is 7000lbs. Plus at $2100 to $2800 dollars for the price is hard to beat. https://www.carsontrailer.com/trailers/car-haulers/california/
I am also adding Curb Weight of all the vehicles that I plan haul as well.
CCCH Weight: 1700 ish lbs
E63s: 4515 lbs
Santa Fe: 3960 lbs
Focus ST: 3223 lbs
The trailer and the E63s would weigh about 6200lbs, That is well within the GVWR of the trailers. However it could be over weight for the hitch extension. However, all of my other vehicles are good to go.
All of these weights are super important when it comes to safety and insurance. I will explain why later.
So the GVWR of the truck is 15,000 lbs. That is the weight of the truck and what truck can carry safely. Then there is GCWR. That is Gross Combined Weight Rating. I have the Factory Ford 2000 RV and Trailer Towing Guide for my truck. Since my truck has the 7.3 Liter Powerstroke, with the 4.88 rear end gears the GCWR for my particular truck is 26,000 lbs. That means a fully loaded truck, with a full loaded camper, a trailer and car cannot exceed 26,000 lbs.
So:
Truck: 9000 lbs
Camper: 4,150 lbs
Trailer: 1700 lbs
E63s: 4515 lbs
Total Weight: 19,365 lbs <This is total max weight for what I plan to carry/tow. I will 100% weigh this whole exact set up, just to see. However, I am well under the GCWR.
Obviously towing the Santa Fe or the Focus would be lighter.
Knowing these numbers are super important because of insurance and DOT requirements. Being over weight stresses the truck and limits it's capabilities. Most trucks will pull overweight no problem, however stopping is your biggest issue.
Just because you can do something doesn't mean your insurance policy will cover you if an accident happens. In fact, it could expose you to lawsuits that your insurer may not defend.
Some insurance companies won’t care, but others might use it as a reason to deny coverage. A common justification is labeling the situation as an “intentional act.” While you may not have intended to hit anyone while towing, you did intentionally exceed the vehicle’s rated weight capacity—and that alone could be enough to void coverage.
I have zero doubt DOT/Highway Patrol will probably pull me over at some point when they see this monstrosity roaming the land. However if I have all my documentation and my weights are good, all should be well. Unless I am speeding ect.....
E63s: 4515 lbs
Santa Fe: 3960 lbs
Focus ST: 3223 lbs
So:
Truck: 9000 lbs
Camper: 4,150 lbs
Trailer: 1700 lbs
E63s: 4515 lbs
