Thank you. I agree the 99/00 are super cool with the all amber turn signals. I am not going to facelift the truck at all. I love the way it looks personally, and the only thing I would really do to the exterior would be getting the dent in the passenger side rear door fixed.
The interior will consist of updates. I want to upgrade the sound system and update the stereo head unit. I really want XM radio and wireless Android Auto.
As for the axle refit, I would have to find another F450 or F550 to complete the swap. The F450/550 came from the factory with "wide track" so I do believe the F350 front axle will work, I would just lose the "wide track".
Maintenance right off the kick will be:
Make sure that there is a new cam position sensor in the glove box.
Making sure the exhaust back pressure tube is clear and that the sensor is working properly.
Maybe a new 86D high pressure fuel spring.
I need to make sure the up pipes are not leaking.
Obviously, look for fuel leaks, oil leaks, coolant leaks. Check belts, hoses, ect.
Mods:
I don't know as of yet. I will have to look at the truck and see what is done. I do know Jeff did have a programmer on the truck at one time.
If it is still stock:
S&B or Banks Intake with the Zoodad mod.
Banks TransCommand
5 inch turbo back exhaust.
Edge Monitor/Tuner with EGT probe. I will not use the Edge boxed tunes.
A Hyrda Diesel Tuner with probably a Gearhead Tune.
The 7.3 Powerstrokes are rated from the factory with 235 hp and 500tq. They are widely regarded as one of the most reliable diesel engines, however they are notoriously slow. With the Mods above they pick up around 100 hp and another 150 to 200 lb tq to the tire and stay relatively reliable. Again not looking for a race truck, just something that is a bit quicker, and might get better fuel mileage.
