Funmart6
my name is mud
Okay, I have recently changed the rear brake pads, rotors are turned and squeaks are gone, except a hooting sound coming from the drivers side. At first I thought it could be a wheel bearing but the sound has only come about since I changed the pads. I was just reading "Rear Wheel Hooting" at V8SHO found in the "Care and Feeding" section, and in that post, a person describes exactly what I am experiencing and is told it sounds like stuck slider pins. There is an exploded diagram of a brake caliper also, now here's the question.
How do you remove the slider pins, or do you have to remove them in order to lubricate them.
Well, I think that I have finally found the cause of my frustrating noise. I had originally thought that the "hooting" sound was coming from the driver's side rear brake caliper so I lubricated the slider pins on that side, checked the passenger side and found that the bottom pin is stuck, and I mean STUCK! I should have noticed this when I changed the pads last week, but..... I didn't
