Size of Brake line?
Ishodu
I am going to be by passing my rear Bias valve soon and I am just wondering if anyone can tell me what size line we have back there so that I can get all the parts I need ready. I never had to do any line work on this car yet.
DeaconBlue
Cleveland, Ohio
You can remove the linkage arm from the valve to the trailing arm. Then remove the pin assemblies from the valve and replace them with plugs.
Ishodu
My idea is to just cut the lines join them together and then take that whole bias valve out of there. I just need to know the size of the hard line so that I can get the unions and what not.
DeaconBlue
Cleveland, Ohio
Okay but make sure you have the correct brake line flaring tool. Not sure about the line size, but a set of calipers will get you the info you need.
Ishodu
Ya I got a double flare kit, I have done brake lines before just not on this car. I guess the weather is better out now, I should be able to go get the info I need myself.
