side lights
fuhSHO
Seattle, WA
are those side lights that light up when you put your blinker on at night on one fuse, cause both mine dont work. i havent checked bulbs yet but i figured i'd check fuses first, so are they indepently on their own fuse? thanks - chris ahl
BlackOnBlackATX
Dutchess County, NY
im pretty sure they share a fuse with something else actually. is there anything else not working in the car? youd be best off looking in the owners manual to find out. i had a bit of fuse trouble myself this weekend. scared me into thinking my computer had gone bad :rolleyes:
fuhSHO
Seattle, WA
yea ill check the manual, just wanted to see if someone here knew off the top of their head. thanks- chris
Slo-Sho
It wasn't me!
Crossroads, CNY
Those #194 "peanut" bulbs are most likely blown. They are cheap and easy to replace. They are on the same circuit as all the parking lights.
If you are talking about the cornering lights.....
They should be a larger bulb that shares the same base as the 194. Can't remember what they are now. They are also controlled by a separate circuit in the MultiFunction Switch and only work when the headlights are on and the key is in the run position.
<small>[ July 07, 2003, 07:06 PM: Message edited by: SHOZ123 ]</small>
