Sho won't start HELP!
mattshowagon
michigan
Turn the key, seams like a bad connection, starter is not getting power, the relay just clicks. :mad: It only happens 1 in 10 times you try to start it. I replaced the batt, starter relay, starter, all connections and wiring. I think it has somthing to do with the igniton. If it does not start, you can dump the clutch to start it. :bonk: Sometimes if my car runs hot it shuts off, and the same thing happens. Could it be the gray box relay thing on the side of the intake manifold? :confused: Any suggestions would be extremely helpful. thanks matt :huh:
