SHO Source Catback Group Buy
CademiaX
What's an SHO?
Utah
For anyone else installing with the provided clamps, you definitely need to tighten those things more than you'd expect to keep everything tight, espcially where the resonator section attached to the beginning of the tailpipe near the gas tank. This is a critical connection that supports the 90 degree bend and keeps it from hanging down.
I have to agree there. Also, even tho it won't leak with the u-bolts the pipe can still twist. Mine did that the other day. I had it realigned at a shop and tack welded. I will have it fully welded when I get the new y-pipe in there.
ForcedSHO
Stupid SHO
New Jersey
Got everything installed at the Meineke down the street from me. They welded up a bolt plate to connect it easily to the y-pipe. This way when I do the y-pipe it will be a lot easier. Quite happy with the overall sound of the Magnaflow resonator and mufflers.
Thanks again guys.
K-Dawg
Treasure Coast, FL
Gah! The SHOSource website is down. I'm in the middle of installing my exhaust and I'm not quite sure on how some of these hangers are supposed to go (especially the ones at the back for the single exit exhaust).
And I assume that the two black bolts go on the ******?
K-Dawg
Treasure Coast, FL
It looks like the included bolt replaces the one that holds the bumper bracket on? Then the bracket and nut go on the end of that. I just had to hog out the hole in the bracket to get it to fit. The frame was in the way. I would suggest including three flat washers to go on that bolt in future kits.
Nice hiding spot for the ****** gasket. Almost threw that away. ;)
