sho shop springs
yhardy1273
orlando,fl
Are SHO shop springs truly lower than Intrax and Eibachs?
1993 SHO
5 SPD.
EIBACH SPRINGS
SUPERCHIP
FLOWMATERS
K&N CONE FILTER
18X 7.5 ALBA BLADES
225/40/18
AND A WHOLE LOTS MORE
DfwSho
Arlington, TX USA
The original Linear springs are much lower than the Eibach's and Intrak's. Add in the eventual sag and you'll be sittin' low, G.
Laurence
Dfwsho
94 mtx, 17x7 SVT Thunderbird, 235/45/zr17 Kumho Ecsta Supra 712, Eibachs/Tokicos, '96 brake upgrade, Perf. Plus y-pipe, UDP's, dynomax, Jared Beck reinforced motor mounts, K&N, PIAA 1500XT, Gen3 badge, TX plate "MTX SHO", Alpine CD, "Yamaha" badges
Gtech Pro 0-60mph 6.36, 1/4-mile [email protected]
98 Suzuki GSXR600
1/4-mile 11.66@119mph
yhardy1273
orlando,fl
Well this guy gave out measurements and they where like 1.5 in the front and that is about the same as the intrax sprins so if the go lower then how is that????????
1993 SHO
5 SPD.
EIBACH SPRINGS
SUPERCHIP
FLOWMATERS
K&N CONE FILTER
18X 7.5 ALBA BLADES
225/40/18
Blast7
Rochester, NY
They're a little expensive in this auction but it would, otherwise, be very difficult to find them. http://cgi.ebay.com/ebaymotors/aw-cgi/ebayISAPI.dll?ViewItem&item=600532861&r=0&t=0
Car of the Moment
1991 Black MTX
K&N Filtercharger
PP Motor Mounts
PP Y-pipe
Rod Shifter
Blazer Tech Fogs
"ur gonna love that sho, and everytime something breaks down..your gonna swear to all your friends that its going up for sale. and the minute you get it back you fall inlove all over again."~Blue
FordLover
Houston, Tx
What are you talking about dude? ..scrape..bang.. They aren't low at ...bump.. all. Scrape..scratch...grind...
-Martin
AOL IM: FastTaurusSHO and Kyle5324
My girl
92 Silver UDP's, coneless, Alum SFB, SHOnut motor mounts
93 Green MTX, High Rev's Jr, lightened flywheel, grizzly paw TOB, fishtank lights, SHOnut motor mounts, K&N panel, coneless, SHOshop linears, tokicos, alum SFB, 26MM RSB, wigwag headlights, 225/55ZR16 firehawk SZ50's, G-tech [email protected], 0-60 in 6.31
My Webpage
yhardy1273
orlando,fl
So are they our not I am curious if they are lower our not.
1993 SHO
5 SPD.
EIBACH SPRINGS
SUPERCHIP
FLOWMATERS
K&N CONE FILTER
18X 7.5 ALBA BLADES
225/40/18
94shoboy
south shore, mass, usa
yes they are lower. we don't have exact numbers because they haven't been produced in a while. i don't think intrax lowers 1 1/2 inches. i think SS would lower around 1 3/4- 2" in front and 1 1/4 in back.
RI-SHO
B to the BANNED
Pawt., RI
You arent lying:
<center>Before
</center>
<center>After
</center>
________________________________________________
Click To See My Modified 1993 MTX SHO
[This message has been edited by RI-SHO (edited 02-02-2002).]
RI-SHO
B to the BANNED
Pawt., RI
Yes Yohancee, in the long run they are lower than all of the lowering springs ever made for SHO. I got mine about month before SHO Shop discontinued them, glad I did.
CTOESHO
DeKalb, IL, USA
Are there any disadvantages in having the SHOshop springs rather than Eibach or Intrax? Why did they ever discontinue making them in the first place?
Mike
93mtx
ThrillSHO
Wake Forest, NC, USA
I don't think there are any disadvatages to them. I think it was just economics. Eibach and Intrax are bigger operations and could probably produce springs cheaper. Add to that, most people prefer a mild drop to a near 2" drop and Eibach and Intrax appealed to a wider market and out sold the SS springs. I had them on my car for 2 years and loved them. I recently sold them on ebay since I've switched to coil-overs.
ThrillSHO Racing
93 ATX SHO
UDPs, LPM, 80mm MAF, K&N w/CAI Snorkle, 8mm Taylor wires, Koni Struts, IPT Coil-overs, Camber plates, Adjustable rear control arms, Touque box brace, Poly bushings, 24mm front SB, 26mm rear SB, Shaved Alum SFB, Full-length SFCs, Front & Rear STBs, SS Y-pipe, Borla Cat-back, TransGo Shift Kit, Relocated battery, Five point harness, Five 2" gauges below the CD player, 225/50s on 16x7s, TCE/Wilwood Brakes
Very Low Very Fast
jedhead
westminster,ca
I have 3 1/2" clearance between the ground and the bottom of the front bumper cover on my '91 with SHO Shop linears. I started with 3" but I scraped off a 1/2" (just kidding).
Bob
Cobria
Saint Louis
I've got a set of sho shop springs sitting in my garage waiting to be installed. How does everyone that uses them like them. Is the ride sacrifice worth the improvement in handling?
edogg23
Buckley, WA
If you have the extra cash the coil covers from ipt would probably be your best bet because you can ajust the drop you want. I think you can drop it like 3 inches or more with those things.
Erik from Orlando 89 silver SHO 128k miles dynomax cat back w/out resonator, ss y-pipe, ss underdrive pulleys,eibach springs, koni struts, pp motor mounts, 17X8 fitipaldi polaris rims with 245/45/17 zr comp t/a tires SHO FEAR written across the windshield, v1 radar detector quantum tinted windows, custom cold air intake with a ractive heat shield. 14.8 @ 93 mph in 90 degree weather!
DeaconBlue
Cleveland, Ohio
With any drop of over 2" you are going to roach the CV joints in the axles. Might look cool in the driveway or at a car show, but you are asking for real problem. Best bet is to go with the Intrax slight more drop than the Eibach's and trim the stop tab on the back side of the strut. This allows the strut to be lowered inrelationship to the hub by another 1/4" to 1/2". If you have Koni's, this isn't an option because the securing bolt on the bottom of strut tube will rub the CV joint's boot.
95 MTX
with a few mods
RI-SHO
B to the BANNED
Pawt., RI
**** YES!!!! and I dont even have SB's or SFC's.
Are you talking for SHO's or all cars in general? I had my SS springs since August of 2000 with no problems not even camber issues with my 18's(camber is within stock spec w/o camber kit). Plus my car is a little lower than what the SS springs allow b/c of the "custom" work I had done. I guess some ppl aren't knocking on wood as often as they should be to rid of these problems you speak of
SHODUDE
Valdosta, GA
We don't have exact number because even when they were produced, some dropped 1 inch while others dropped 3 or more inches. Very poor quality spring. You take your chances when buying these used.
mailto:[email protected][email protected]</A>
1990 SHO FOR Parts
1991 SHO SOLD [email protected]
Need SHO parts?
Click here&gt; http://cgi6.ebay.com/ebaymotors/aw-cgi/eBayISAPI.dll?ViewListedItems&[email protected]
yhardy1273
orlando,fl
With some not dropping the car the full amount that is enough right there to make me steer away from them. What piece are ya'll talking about shaving away on the strut. If shaved will that make it lower.
1993 SHO
5 SPD.
EIBACH SPRINGS
SUPERCHIP
FLOWMATERS
K&N CONE FILTER
18X 7.5 ALBA BLADES
225/40/18
