SHO Severe HPFP!
Livernois Motorsports
SHOForumSponsor
Sponsoring Vendor
Dearborn Heights, MI
Firestorm High Pressure Fuel Pump for Ford direct injection engines! Our extensive work with the Ford Ecoboost family of engines has revealed a common road block when trying to add more power; the factory High Pressure Fuel System. While the factory fuel system is adequate for stock vehicles these engine quickly run out of fuel with even basic performance upgrades. To help combat this, we have developed our New Firestorm High Pressure Fuel Pump Upgrade kits for the 3.5 Ecoboost in passenger cars like the Taurus SHO and the Lincoln MKS sedans. The new Firestorm Fuel Pump supplies up to 60% more fuel than the factory fuel pump. This is a complete bolt on upgraded kit included is the new high pressure fuel pump, new custom fuel line and hardware to make installation easy. While the installing of the pump is fairly easy it must be accompanied by custom tuning to work correctly. If you already have a MyCalibrator tuner contact us for your free update, if you don't have a MyCalibrator tuner one can be purchased separately with the file required to use this great new fuel pump.
680 h images ePIM original High Pressure fuel pump
SHOForumSponsor
Sponsoring Vendor
What kind of hp gains for 1600 bucks?
By doing a fuel pump by itself you do not gain any HP it gives you more reliable fuel delivery where the factory pump would starve itself with even minor mods to the vehicle, usually to go any further such as doing upgraded turbos this is one of the other parts required to accomplish this
BamSHO
South Williamsport,PA, US
This will allwo you to do a 50/50 mix but the injectors is what limits you from there
The $2500 pump will let you run full E85, but you will need a boost a pump to help increase fuel from the tank pump to the DI pump. Also 10 to 12 cars will need injectors, but the 13+ cars don't. Has to do with the different ECUs in those cars.
SHOForumSponsor
Sponsoring Vendor
No the 13+ still need injectors for full e85 none of the shos will run that without bigger injectors
