Tommy's SHO
SHO Member #535
Hey guys, I'm having an issue with the SHO.
Last month i washed the engine with some simple green and rinsed it off with water. I then had a problem with it firing all of it's cylinders. My fault as I used to much water to rinse the engine off which in turn filled the spark plug tubes with water. I sucked out the water and cleaned the tubes. I left the car to dry out for a week and then went back to it and still had problems with it. Took it on the highway running on 5 cylinders and whatever was wet dried off and then the car was running like it suppose to. Continued to use the car for the rest of that week with no issues.
Fast forward to today, I started the car up after sitting for almost two weeks and started right up. Took it out on the highway merged nicely and then loss of power....engine is stumbling.....tach is @ 600 rpm and stuck there. It sounded like the car was in limp mode. My dash lights were out clock/EATC and all the lights on the instrument cluster were lit. Pulled over off the highway and the engine was struggling to run. I shut her off.....big mistake as i couldn't restart her because when i tried to it sounded like she had a dead battery. Checked out the batt voltage and it read 8.5 volts. hmmmm weird. I disconnected the battery from the car and it read 11.5 volts....ok so i reconnected it and it still read 11.5 volts WTF? Tried to start it and it wouldn't as the battery did not have enough power to start it. Finally a nice guy pulled over and gave me a boost and it started right up, ran like it was suppose too. Thanked the guy and i was off. After 10 seconds of driving, it all started again. engine bogging, tach not working, no lights, WTF? I drove the car home as it was doing this slowly and when i got home I disconnected the battery.....The car was running rich because my tailpipes have black soot all around them. I'm annoyed at myself because I most likely destroyed the catalytic converters by doing this but....that another issue.
Could a bad battery do this? What should i check for? It's a '95 with 108k miles.
