SHO NUT clutch set, opinions please
misteramx
Lewiston Idaho
I'm thinking of buying the SHO NUT clutch set,PP,disc,TOB, and pin for TOB. This is an OE set. Anyone use this set? For $219, the price is right, but how about the quality.
SLOSHO89
San Luis Obispo, CA
I put one in my SHO. I liked it. It looks like the one I took out.... No complants.
Slicers, SHO+ hood and spoiler.
SHO SHOP Y-Pipe
Silver-Blue '66 Mustang Fastback
E-mail, [email protected]
AIM; SLOSHO89 I like to talk SHOs:)
shoupu
ontario
josh from shonut put that clutch in my 89 and i am happy with it...........
misteramx
Lewiston Idaho
Do you guys remember if was a remanufactured clutch, Ford OE, or brand new aftermarket? I think either Valeo or Luk made the Ford OE unit.
If this is a new unit, I think it will fit my needs very well...and save me $100 in parts.
RStalveyARFF
too many shos
Georgetown, MA
Dude, the clutch set is from SHO NUT, from Ford. It is exactly what the dealer would get you. Just make sure you install that TOB right, and threadlock the PP to flywheel bolts.
philw349
PhilW
Tucson, AZ
It's definitely OE. I have the same kit, but I got the wear parts too, and the ceramic bearing.
olympic
Saskatchewan, Canada
SHOnut's kit is made by Valeo which also produces them for Ford. I got mine from him and have no complaints on quality. The ceramic TOB is pricey but worthwhile.
jthomas68
Area 51
If i got more straps for the PP,would it be possible to drill out the rivets and install stainless stell cap screws myself?I can get the extra straps to put in,but would like to upgrade it myself.
Jeremy Thomas
Juiced 91+
SHO Pic Of The Week:
philw349
PhilW
Tucson, AZ
Originally posted by misteramx:
What exactly is the benefit of the ceramic TOB? I've been trying to find more info, but nothing yet.
From what I understand it changes the wear pattern of the Throwout bearing. It's always under wear, the way its setup, and the ceramic has some good friction or heat protection (it looked metal to me, but then I'm no mechanical engineer). It's supposed to make the clutch last until the friction disk is worn out, giving extra years of life for your clutch (in theory).
olympic
The ceramic bearings inside the TOB have less friction. So the TOB spins up faster when it contacts the clutch fingers. Therefore the TOB spends less time slipping against the fingers and causes less wear.
SHODUDE
Valdosta, GA
drivinhard
Gainesville, GA
Jeremy, you'd have to take it to a clutch shop afterward and get them to align the cover/plate, and balance the whole unit. But yeah you could do it yourself.
White 92
SR71SHO - racer '89
gregr
Orange County, NY - USA
Got my SHO Nut clutch installed by drivinhard this summer. All is good. I would recommend it. The price is right.
Greg Raciti
SHO Forum Webmaster
93 Emerald Green MTX
Performance Plus high flow stainless Y-pipe
Scott 2.5" Stainless
Exhaust with Edelbrock mufflers
SHOShop Cold Air Induction
SHOShop Underdrive Pullies (to be installed)
Romar Enterprises Subframe Connectors
SHO NUT Performance Aluminum Subframe Bushings
24mm front sway bar
26mm rear sway bar
Energy Suspension poly bushings
SHOShop LPM
SHOShop UDP's (coming soon!)
IPT triple gauge pod with Autometer - Volts, Oil Pressure, and Water Temperature Gauges
misteramx
Lewiston Idaho
Just ordered the clutch set SHO NUT, $219 to my door along with the lower control arm pinch bolts. Very friendly guy named Nick, answered all my questions and even gave me some tips for the install. Thanks for all the comments, now just get my tranny guy lined up for the install and Ill get my SHO on the road! Lets see, radiator showed up ($163 with tax), clutch and parts, $228, with labor for the clutch, I should be into my car just under $3000. Not bad since the motor has a verified 43K on it. Car itself has 157K on it, so brakes are long overdue as are the rear struts. Bot my goal of keeping this under $5000 seems realistic I think.
Thankds again folks...
