SHO NooB here.
ShoJosh
WI
Since i can't post anywhere else I guess i'll post here.
First off i'm new here.
But I have some questions. I'm going to be owning a 92 SHO
very soon here.
I was wondering. If i'm going to go for speed and performance.
What is the first mod is should put on it. Thats not TOO terribly expensive.
Or just a list of what i should do first. (The car is stock i'm assuming)
Thanks
1993MTXSHO
Its a Taurus...
Jersey
welcome, first mod, MAINTENANCE. Do it, you will thank me in the end. The car will run a lot better and for a long longer. After you have done ALL of the maintenance, yes a y pipe is the best first mod for an mtx sho. There is a group buy going on now for a nice equal length pipe right now for a pretty good price, I suggest you get in on it;)
Y pipe buy:
http://www.shoforum.com/showthread.php?t=92186
1995SHO9
FLEES ARE COMIN
Carlisle PA
I'm going to agree with Nick here and say that you should do the maintnance first.
After that I suggest:
1. 96 break upgrade
2. Catless y pipe
3. Big bore butterflies
5 Extrude honed intake
6. Zex is going to be the best bang for your buck. Although filling all of those bottles can get expensive!
38SHO
#1 Oil Abuser
North Palm Beach
first things first,get on that y pipe group buy NOW before its too late, later you will wish you had one.......
then when you get the car do the rod bearings
replace your brakes if they don't work good, get better tires if yours suck......
fix all leaks on car
fix all check engine light problems
fix loose rod shifter bushing problems if it has any
then start doing some more mods
Aluminum subframe bushings, 94-99 neon front strut tower bars on ebay are cheap and can be made to work on our car... front or back, the front neon bar works anywhere... I suggest back first
check out your swaybars and get a good combo if your mismatched
fix engine mounts if any broken
do all this and your SHO will be riding pretty good......
then you can figure out what all else you need
Kens1992mtxSHO
The Commonwealth
Welcome!
Lots of good advice so far. Listen to what the voices in your head are telling you.
bottonic
Sho ******
East Troy, WI
Welcome :thumb:
First mod should be a SHOforum.com decal. I heard it adds around 50 HP :wave:
Seriously though, listen to these guys. Getting the maintenance up to date is a must before any performance mods.
thatSHOguy101
