SHO motor in a Bronco II?
Joe_SHO
ND
I've seen lotsa unfinished dreams regarding SHO motors in a Ranger. From what I've read it seems as though the motor will bolt up to a 3.0 bellhousing/tranny, but not a 2.3 tranny. I have a Bronco II with a 2.9. Anyone know if the 2.9 transmission will bolt up to the SHO motor? Thanks. -Joe
Off Road SHO
Moderator
No, it wont. The 2.9 and 3.0 are different patterns. With that said, with money anything can be made to fit. The 2.3 and 2.9 trannys are also built to only handle what those two motors put out; the SHO motor will make short work of them.
Jeff, a SHO buggy guy in Tucson has a friend that put a SHO motor into a Bronco II frame and built a roll cage on top of the frame. It is an automatic and it hauls A$$. He takes it on long desert rides with true buggies and quads, and none of the quad riders want to be ahead of him in the line-up. He puts it in low-range and lets the automatic do its job. I've got pics of it somewhere, I'll try and find them. He did say that an aftermarket tranny cooler is a must.
Tom
rktmn
Well-Known Member
miami
I have a 4X4 Bronco II with a 5.0 and a T-5 Tranny mated to the original transfer case.
You can mate the SHO engine to a T5 with an adaptor plate. It should not be too difficult to do.
Jose
Joe_SHO
ND
my situation is i have a BII with a stock tranny, stock t-case, old leaky 2.9 motor, and a rusty old SHO with a good motor. if it was easy as putting in a motor and wiring i'd be down, but i already replaced transmission and transfer case.
you should probably sell me that 5.0 bronco II though.
rktmn
Well-Known Member
miami
I am using the stock transfer case. It has 230,000 miles.
The T-5 uses an Advance Adapter transfer case adapter. I have a dana 44 twin torsion beam in the front and a 9" Currie rear end. They have been narrowed to fit under the Bronco, but they track 15" wider than the stock running gear.
It also has an Auatofab Fiberclass Kit:
http://www.autofab.com/mdl_44_ranger.htm
It is a neat little truck, and it is my daily driver. I trade the use with my SHO, when the SHO is down.
It took me 2 years to put it together.
Jose
gmail
Well-Known Member
sunbury pa
usless info for you... the 2.9 manual and the 89 SHO shared the same clutch
