Quick history: I changed the valve cover gaskets and spark plugs, cause I was getting oil where the spark plug seats. When I started the car, the belts were squeaking ( worse than it had been doing prior ), it had a rough idle ( I had to keep giving it gas for about a minute before it idle on its own ). Once the belts quit squeaking, and the idling balanced out, I took it for a spin through the neighborhood. It drove fine for about 5 minutes before shutting off without warning. Would not start back up, so I pulled it home. The next day, it did the same thing ( squeaking belts, rough idle, run fine, shuts off, then won't start ).I have checked for any unconnected connectors, and unhooked vacuum lines. Any suggestions would be greatly appreciated.
