SHO hesitation when shifting
witstick
Lebanon, PA
Hi my 93atx hesitates after it shifts gears then its fine, kinda shifts like from first to second..bucks and hesitates a little then catches hold and goes, what could be causing this? Just had the 60k done and new plugs and gaskets, Maybee tps Problem????
witstick
Lebanon, PA
it does it after it right after it shifts gears, feels like tranny is grabbing but engine is hessitating, it weird.................it only last a second or 2 then goes away.........also feels like car bucks a little at certain speeds especialy in overdrive at lower speeds...............hmmm?
SHOtimer
#2910
Santa Clarita, Ca
Does the car have any 60k history? Is their oil in the plug wells? If their is no history and the wells are full of oil, that will certainly hinder the car and might explain the issues you are having. A dirty MAF might not be the sole cause, but could definately contribute.
Does it 'hesitate' at all RPM's when going into second...i: does it matter how much gas you give it on whether it will hesitate or not?
Doug
poffffd
