SHO bi/twin Turbo
Art5
white plains, NY
Hi , everyone, I'm working on my Gen2 and was thinking to do bi or twin turbo. I know i need forged pistons and maybe crank, but is there potential to do something like that? Let me know what you guys think. Thanks
93rev2sev
Hockeytown
if you scroll down just a little further ...
there's a whole section devoted to answering your question.
SHOspazz92
Banned
Triad Area, North Carolina.
You do realize the stock Crank is Forged, Don't you?
So what do I think?
Well based off that one statement, I would suggest doing a search.
-Sam
Art5
white plains, NY
I know that there was something done to make it stronger then stock taurus crank, but i don't know how stronger though.
Toolman
Boost it!
Grand Lake, Oklahoma, USA
Welcome to the forum. There is a sticky in the 'Forced Induction/Nitrous/Tuning' section about turbocharging the SHO. A little long-winded, and the author is a bit of dipwad, but some good info nevertheless.
IMO, keep the stock pistons (they will support more power than your transaxle), and spend that money on other supporting mods (fuel system and tuning for instance). Even starting off with a junk-yard turbo is ok, just to get your feet wet. Just make sure and have solid supporting mods (proper MAF, quality hotpipes, quality WG, injectors, WB and other gauges). Once the cheap turbo blows, you will have some experience under your belt, and the rest of the setup will be ready for the quality hand-picked turbo that will power your SHO for the rest of it's days.
firebat45
Edmonton
how about block? I thought block was vulcan.
Nope, it's Yamaha. Honestly, you should not be looking at turbocharging the engine, you obviously know very little about the car. That's not meant as a dig, I'm just trying to be frank. Drive it as it is for now, in a year or two once you've learned about it more, then think about turbo.
HotRodKid
mmmmm ... turbo
Western NY
the engine needs pistons, but only if your planning on making a good bit more then 400hp
the only thing vulcan about ANY of the SHO's was the engine in the test mule car, the prototype SHO engines done with a vulcan block did not survive durability testing, so Yamaha created all new EVERYTHING
twin turboing a SHO engine should only be done if the engine is no longer in a SHO, a TT SHO motor in a SHO chassis thats still FWD is going to be a nightmare of a build
however TT'ing a SHO engine is a great option in anything RWD where the engine is positioned the PROPER way
Toolman
Boost it!
HAHA hotrod, the S.H.O. engine is positioned just fine! And as it sits from the hand of the Yamagods themselves, with nothing more than a single turbo, is how it will reside as the quickest and fastest S.H.O. powered vehicle out there!!! Throwing the gauntlet!! 2010 is the year of the SHOspeed Project!!!
(probably not really)
Westerly, RI
I didn't get that wild, but I did think that perhaps someone may have cleaned a throttle body with carb cleaner again.
I said a novena.
sho_sc
Georgetown, KY
Wouldn't that be picking up the gauntlet?? :sun:
