Shifting problems
bolsterboy
South Side Chicago
So we just put in my clutch less then 10k ago, and im already having driveablity problems. I did a clutch adjustment, but i only go one click and i changes from not going in and out of gear at all to slipping under heavy throttle, thats from one click adjustment on the clutch, this car is realy making me want to buy a turbo coupe :evilgrin:
ohfosho
ontario SHOwner
ontario, canada
well it depends what you put in there 10k ago, and how you treated it.
i had a new (cheaper) cluth put into my old 91 ford ****** gt, and a year later i blew the diff, so had a new tranny put in and the clutch was about half worn...i did beat it a bit though...after all i did blow the diff... whats with ford FWD's and diff probs anyway?
shofan33
Slick Silver
Edison, NJ
You should really check your motor mounts if it's under heavy throttle.
