jayro
Hi,
I am having some issues with going into gear when I am parked. Details are....
Car shifts fine when driving. No problems with upshifting or downshifting. If I push in the clutch before I come to a stop then the car slides into gear as smooth as silk, but if I let the clutch out at idle and then push it back in the car does not want to go into gear. Any gear is harder, but it will usually go into 3rd and up. Once it goes into a gear (doesn't matter which one) then it shifts into all of them fine. Here is the info on what has been done so far.....
New SB stage 3 clutch, new clutch cable with new cable bushings, new rod shifter bushings. Fluid is new and clean. I tried switching from Maxlife to Mobil 1 with no effect. It is almost like the clutch isn't quite disengaging all the way. Feels like it needs one more "click", but it won't. I know I read a thread about how to manually adjust it a while back, but now I can't find it. I think it was started by Texas Tony or one of the Texas guys. Thanks
