jmpSHO
My speedometer on my 94 ATX is shaky/bouncy at certain speeds. The VSS and lower speedo cable are new. Is this a sign that the speedometer is on it's way out or do I have a bad cable? The only one left to replace is the upper.
Mine works fine up until i hit 75. Once i hit 75 it will jump to 90 and then i hear a rattle type noise coming from the cluster. If i give the dash a good wack on top it will jump back to 75 for a moment and then back up to 90. The rattle goes away when it goes back down to 75.
So my speedometer stopped working today. In case anyone wasn't following my older threads I had a problem with it a while ago. I bought the car with it not working last year and I found the upper and lower cables disconnected so I hooked them back up and it woorked for a bit then it did this bouncing up and down thing, it would drop from 70 to 0 MPH and then back up to 70 MPH and then stopped working all together just like it did today. VSS and lower speedometer cable are new, just replaced them a few weeks ago and like I said it worked up until now.
Bad head. If it actually stopping then starting like that I would guess bad head. My 92 had an issue with that.
