Shaky speedometer.
jmpSHO
Massachusetts
My speedometer on my 94 ATX is shaky/bouncy at certain speeds. The VSS and lower speedo cable are new. Is this a sign that the speedometer is on it's way out or do I have a bad cable? The only one left to replace is the upper.
jmpSHO
Massachusetts
I went through alot of work to get the stupid thing to work and I was really ****** to see it shake at certain speeds.
jmpSHO
Massachusetts
So my speedometer stopped working today. In case anyone wasn't following my older threads I had a problem with it a while ago. I bought the car with it not working last year and I found the upper and lower cables disconnected so I hooked them back up and it woorked for a bit then it did this bouncing up and down thing, it would drop from 70 to 0 MPH and then back up to 70 MPH and then stopped working all together just like it did today. VSS and lower speedometer cable are new, just replaced them a few weeks ago and like I said it worked up until now.
Irish Pride
Irish Inside
MusicCityUSA
Mine works fine up until i hit 75. Once i hit 75 it will jump to 90 and then i hear a rattle type noise coming from the cluster. If i give the dash a good wack on top it will jump back to 75 for a moment and then back up to 90. The rattle goes away when it goes back down to 75.
jmpSHO
Massachusetts
It started working again today but I think I am going to swap the cluster and upper speedometer cable to see if that fixes the problem.
tommyturbo
California
My 95 MTX will fluctuate on a really cold morning at about 70, it jumps + or - 3-5mph when you speed up or slow down a bit....but once warm is smooth. I had a 92 LX and it was really shakey at all speeds untill the torque converter locked up, and then it was smooth, never did understand that.
-DVP-
NaNaaNaNAAAA!!!
0 .· ` ' / ·. Full Retard
Bad head. If it actually stopping then starting like that I would guess bad head. My 92 had an issue with that.
