SFC's...?
TYSHO
Earth
Does anyone have a pic of SFC's installed? I haven't actually seen these things, but from what it seems, they are welded to the SF? So is it actually welded like that? I'd hate to do another clutch job if those are welded to the SF!
M
MyBlue92SHO
Guest
Hello! What I've been told is they stop right before the subframe and that you should definitely get some!!
TYSHO
Earth
So I'm guessing, they're welded under the floor board?
SHO5
ADDICTED
Fond du Lac, WI
where can you buy these things. Ive been searching and the link just leads me back to the shoforum homepage.
ddawson
San Mateo
Here's mine.
TYSHO
Earth
These look pretty easy to make, wonder why everyone wants a lot for them! Thanks for the link and reply w/pic. Looks like I'll have some made!
fricker66
ddawson:
Here's mine.
How do you have access to replace the fuel filter? Maybe it's just the angle of the picture but it doesn't look like the filter would slip down through the opening. Just curious?
RI-SHO
B to the BANNED
Pawt., RI
SuperG:
That photo looks like the frame is being pre-stressed...is that so?
Looks like its been on there for awhile so he probalu just took a picture while it was on a lift to show them to others.
You defitnaly DO NOT want to weld them on while the wheels are hanging and the frame de-stressed with no weight on it.
92sho16
b00sted
Liverpool, NY
RI-SHO:
SuperG:
Can you put some jack stands or wheel ramps under the wheels? If you dont have a lift this would be the only way i could see a DIY doing this job.
When mine were put on the wheels were hanging and the SFC was supported. Then the body was dropped a bit to put a slight bow in the SFC before they were welded in place.
RJ-92
Crappy NYS
92sho16:
I wouldn't recomend it. You want the chassis to be simetrical at install to insure proper alignment. Lift = only way to go. Even then measurements should be made to check for the squareness of the cars chassis before welding.
RI-SHO
B to the BANNED
Pawt., RI
A bud of mine had them welded at a local shop with an alignment lift which raised the car by its wheels.
GR8WYT
SHOless
Langley, BC Canada
I had mine installed on a drive-on lift. Makes a huge improvement in the stiffness of the body. Highly recommended!
93EmeraldMTX
East Lansing, MSU
does anyone have that picture of its dimensions? it was white with a black background. It seems i went through all the threads from a while ago and the picture isnt there anymore, and the only thing i have it on is a papaer i printed out.
i want to email it to my friend, he can make me a set pretty easily i would think.
Ishodu
SHOZ123:
Exactly what I did when I welded mine on.
