sfb
mef18352
pennsylvania
What are the subframe bushings sold on rockauto? are they all i need to replace my worn ones? I searched here and couldn't find an exact yes or no answer. They look to be one piece.
DORMAN Part # 924000 {OE Solutions #F6DZ-5400155-A}
Front; Lower
More Info
$23.79 $0.00 $23.79
DORMAN Part # 31098 {Pack of 2 #F6DZ-5400155-A}
Front; Lower
More Info
$26.79 $0.00 $26.79
DORMAN Part # 924011
Rear
sho2see
sho2see
Baltimore, MD
If your trying to go to stock bushings I wouldn't...go with the aluminium sfb or the gen3 sfb...the aluminium ones can be bout at shosource and the gen3 sfb can be bout at rcmautomotive.com.
The gen3 sfb are 4 of the gen3 bushings near the firewall.
rpmshotimeeh
Its SHO_time!
MA
bump im also looking to go stock rubber bushings...are they available at ford or? i DONT want to go aluminum. Any ideas on where i could find some. also i looked those up on rock auto 2 but im nit sure about em.
SHOGUN88
1994 MTX
Langley, BC Canada
If you dont want alluminum go with the Gen 3 bushings like sho2see said. Much better option.
sho2see
sho2see
Baltimore, MD
ok so what will i need to order to make that work? like what are the parts i will need?
Go to rcmautomotive.com, then go to suspension, scroll down and you should see the gen3 bushings. I think it cost around $160 for the set. I would paste the link but I'm on my blackberry so but I gave you the info hope that helps you out.
rpmshotimeeh
Its SHO_time!
MA
will this only work on mtx or will it work on atx as well? jw because im about to order them up.
rpmshotimeeh
Its SHO_time!
MA
so i just ordered the subframe bushings about 10 minutes ago and 5 minutes ago got a call back from rock auto saying that they are out of stock with the manufacturer so the order is cancelled.
shotime1994
AirHammerAndrew
New York
I paid $140 for all the bushings and they were better then the old ones I think they might have updated them.
