94carolinaSHO
Hey all
I have a 94 atx and i have a bit of a chirp/squeal coming from the front of the engine. The noise does not vary a lot with the rpm of the engine. The serpentine belt has been replaced but that didnt solve the problem. So i sprayed belt dressing on it and that made it worse and it did vary with engine rpm. So now i suppose the dressing has worn off and its back to doing its own thing. My question is is this the idler pulley or the tensionser? I have done searches and read the sticky so am i correct in that the tensioner is no longer made or is that the one for the timing belt? Im a bit confused. Which should i replace first? Advance carries the idler pulley but no one seems to have the tensioner. Just looking for an outside look to see what im missing. Thanks a lot.
