semi active suspention
stephen newberg
Ladysmith, BC, Canada
Yes, I used that when I put in my swtich, but it will not give you anything for indicating to the system a go to full soft signal, that is, a full short indication supplied. Instead it lets you either go to full hard with an open circuit (switch open) or leave the computer control engaged with a closed switch.
pax, smn
1998v8sho
1998v8sho
Haverford, Pennsylvania
You are right stephen. I am not sure as to how or even if the struts can go into full soft mode.
@jnrock Why do you want them at "full soft mode"?
