Secondary runners opening early
rendyx
Buffalo, NY
Here's an odd observation about the runners:
When we snap the throttle open, we can see the runners start to open. Now, they may open only part way, and then close. In other words, they open gradually, not all at once. Also, they seem to open more around 3200RPMs, if you start from idle. If you hold the RPMs at about 2000, then snap the throttle, they don't open right away (they open about when they should normally). Any thoughts?
jthomas68
Area 51
They don`t "snap" open quickly as if spring loaded,they do somewhat open gradually,so what you`re seeing may be normal.But,if you do think they are opening too early,i`d look into a vacuum leak.They are held closed with vacuum,if it`s leaking,they may not stay closed properly.
rendyx
Buffalo, NY
The problem is that if the throttle is pushed briefly while keeping the rpm under 4000, the runners open up and then close. We just finished replacing the vacuum lines, so I am pretty sure that is not problem.
YamahaSHO
AutoSHO
No SHO = Mo $$$
Fort Collins, CO
rendyx:
YamahaSHO
Sounds like the vacuum canister on the back of the intake is leaking, or one of the diaphragms in the actuators is torn, and creating a vacuum leak.
rendyx
Buffalo, NY
I did notice that when the vacuum canister is shaken, it rattles. So would this be a sign of failure of that part?
AutoSHO
No SHO = Mo $$$
Fort Collins, CO
rendyx:
Sounds like something internal might be broken. Do you have a spare intake around, or access to someone else's car? You could swap it to see if it fixes it.
*walks out to see if his vacuum canister rattles*
srfdude
Oceanside, CA
rendyx:
LOL, not old enough to remember vacuum windshield wipers, eh? When you went up a hill the wipers stopped. When you snap open the throttle, the vacuum naturally drops drastically, and if the reservoir isn't big enough to take up the slack, vacuum-controlled servos, etc. will momentarily operate.
Mike
Trojan Man
Rochester, NY
Hey Pat,
When I was putting my upper end back together a few months ago, I seem to remember my secondaries doing the same exact thing when I was playing around with them. If they only open briefly and then close, I wouldn't worry about it too much.
BTW, I fixed my clutch today and added some Sycromesh... WOOOHOOO!
