Found the vacuum leak.
The vacuum hose to the climate control module was disconnected.
Now the tach stays steady at 1020 or so rpm. Still high.
Sounds like you've found
a vacuum leak... There may still be more...
But the cold start problem I've been having is still there.
It takes two or three times to start the engine.
It just cranks for awhile; then when started I have to goose the throttle or it will stall.
Even when goosing the throttle to keep it going, it is a very rough idle.
This used to only happen on a cold start - if I left the engine off for more than 4 or so hours and overnight.
Now it seems to be happening after only two hours.
1.Turn the key on; cranks
2. repeat (1)two more times
3. Turns over on #3;
4. Engine stays on only if I goose the throttle and runs very rough
5. Have to wait 5 minutes or so before engaging gear and driving off otherwise it will stall or I can "catch it" if I goose the throttle.
NO CODES
Installed as soon as 1 month ago and up to a year ago:
New: plugs, wires, timing belt, CKP, CPS, MAF Sensor
Hmmm...
Have you checked the fuel pressure when this happens? Try this: Get in the car, cold, and crank it for a couple seconds, then take a screwdriver wrapped in a rag (or a fuel pressure gauge, if you're lucky enough to have one around), and check for fuel pressure at the Schrader valve on the fuel rail. As long as you can do this within a couple minutes of the prime/crank operation, you should get a healthy amount of fuel spraying out into the rag (obviously, you'll want to be careful doing this).
Along the same lines, another way of checking for a potential fuel problem is to "prime" the fuel pump 2-3 times before cranking, and see if that changes the "hard start" behavior.
You may already know his, but when you turn the key to the "Run" position, before cranking it, the fuel pump runs for a second or so (you can hear it hum), and this re-pressurizes the fuel line from the tank to the rail.
If your fuel pump check valve (which is designed to allow fuel to flow only in the proper direction) is failing, it can allow the fuel to drain back into the tank, emptying out the fuel line, and that means you need to run the pump extra to fill it back up and get a good steady flow of fuel to the engine.
However, this issue is normally associated with hard starts, but not rough running after starts. When I had the check valve fail on my former '95 ATX, I could prime it 2-3 times before starting and it would start right up and run 100% normally. Your symptoms indicate that you've at least got something else going on.
That said, it is possible that the check valve (which is integral to the pump itself) is failing
and the pump itself is failing in such a way that it's unable to sufficiently feed the engine enough fuel to run normally... Although the more I think about this possibility (and without setting a code), the more I think it's a stretch.
Still, a fuel delivery issue of some sort is my first guess here (especially since the "sitting" interval tolerance is decreasing as time progresses), second is something sensor related, possibly TPS (since it's not on your list of recently replaced).
The fact that it's giving you no codes is perplexing... :braincramp:
One more thing: If you have still got a vacuum leak, that may also be causing/affecting the rough running symptom. You might try running a stream of unlit propane around the engine (focusing on areas where you know vacuum is present) while it's idling, listening for an increase in the RPMs. That may help you find you find any additional vacuum leaks.
Good luck!
Regards,
Jon Heese
