Secondaries, Have Question
Rockledge
Pluggin' away
Connecticut
davidb said:
Thanks for the wireing diagrams. Is the Powertrain Control Module (PCM) the computer??
Yes. It's also sometimes referred to as an ECM (Electronic Control Module).
Cocoa,Florida
why do you want them open sooner anyway?
you understand that the engine breathing threw the
long runners builds tourqe at low RPM's,which is just as
important as HP!,
IMO: leave it alone the factory setting at 3950 is almost perfect anyways
however is you must change it the best way is to get a aftermarket LPM
which can be programed to have the runners open at a RPM of your discression
Rockledge
Pluggin' away
Connecticut
davidb said:
If I were to run my own wire, where/how do I make a connection at the ECM? :eek:
You'd probably want to splice it into the wire harness up near where the connector plugs into the PCM.
Then run the wire along the harness as much as posible all the way to the secondaries controller.
Same thing on the controller end - splice into the wire harness, near the connector.
davidb
Waldorf, Maryland
important as HP!,
You missed the point of this thread. The problem is that my secondaries are not opening as they should. Having them open all the time instead of not working at all was only an option.
Dave
davidb
Waldorf, Maryland
Thanks, work is now in progress. :cheers:
Dave
