Zap
Either there is something I am missing, or I just suck at this... but I am seriously confused about sealing the oil pan. headbang headbang
I started by applying a generous amount of RTV, though I didn't appear to use all of the 3.35 oz tube that I had. I then began to raise the pan up to the block with a floor jack to help with the lifting so I could steady and make sure the pan went on straight. It went on ok on one side, but the other side was just a bit off. It didn't smear, so I figured I could move it and keep going. Before I got it all the way to where I could install bolts/nuts, I realized that the stupid side seal had totally moved around. slap
Are you supposed to install those seals first, and if so, how? They kept falling off the engine when I tried to get them to stay on there. Also, how much RTV is supposed to be used? I have a picture of the pan before I tried applying it, if that would help at all. Finally, are there any other tips that would help me do this correctly? I'm about to the point of torching everything madflame , cuz I've been working on this stupid project on the weekends for the last month and I'm tired of not being able to get it completed. All my free time (other than the tiny bit of time after work every day) is being spent on this car. rant
