jthod
Mr. Goodwrench
Damn, I should have read this before I changed my oil on monday!
The one place I have found this product to do much good is in decarboning a two cycle outboard motor. It is a mild penetrating oil. I do not think it does much of anything on a four cycle engine, except make smoke because it is in fact oil. If you think it is going to remove baked on gunk, try using it to clean an intake. It is relatively ineffective.
This stuff is grade A awesomeness!
I ran it through my intake and fuel system, boy does it make a difference.
I've heard from many people to try it out, and it sure as **** does the job.
I don't know about putting it in my oil, I'm afraid that what ever gunk that built up in my crankcase is actually holding my engine together.
Still have to let it run completely through the fuel system, but I'm going to be traveling 60+miles tonight so it will get a good cleaning tonight.
Anyone else use Seafoam? Opinions?
down the engine with the last of of the
It's the universal product you can put anywhere in your engine to fix damn near anything![]()
+1. Seafoam is the *******. I pour a can in my tank every few fillups and it keeps it running tip-top.
As far as the motor oil goes, transmission fluid actually does an amazing job of cleaning out your oil system if you pour a quart in a few hundred miles in before an oil change.
water into the intake?
You dont have a choice. Its so thin it goes right through the rings. Thats why on the can it suggests you change your oil after seafoaming.
There is a specific way of seafoaming. The correct way. I dont know if its been mentioned, I havent read the entire thread, but the way I do it is this...
Step one, take about a foot or more length of vacuum hose and connect one end to the vacuum tree. If you do not have a vacuum tree then disconnect a vacuum hose that leads to the intake manifold and does not effect the idle and use that. (On the volvo I used the hose that goes from the intake mani to the turbo cbv.)
Step two, rev and hold the motor at about 4k rpms, then dump the open end of the vacuum hose into the can of seafoam. when the engine attemps to stall, take the hose out. Continue this process until can is near empty, then down the engine with the last of of the
Step three, let engine sit for 15-20 minutes as the seafoam works away at the carbon buildup and gunk.
Step four, after the 15-20 minutes are up... drive the car 'spiritedly'. Let the throttle open up a few times. Drive until the tailpipe has stopped exhaling white smoke.
Step five, change your oil.
Done!
just used seafoam on my SHO today!
Results? I'm curious to hear what other people say.
