Sgtmeatsauce1
2013 SHO +pp
I purchased a Torrie tune set up, with sct x4 tuner. I know he has total control over tune, but before I run his tune, 170 thermostat, Amsoil dry synthetic panel filter and custom gutted stock airbox, [email protected], 3bar map, I was going to play with the 3 tunes the sctx4 comes with. After which I would put in plugs, stat, 3bar and his 93 tune....
I know Torrie has basically full control with tune, but what can one do to self adjust any parameters . I thought I would use the stock sctx4 tune for the sho to play around, then when bored, add the sp534 plugs, thermostat, 3bar map and Torrie 93 tune. I am particular when I want my fans on, Max rpm, shift rpm, aggressive shifting in D and S even more aggressive, and taking off top end limiter. I also like to play with shifting feel, the throw you forward shift vs the chirp tires shifts.
What leadway do you get with this scanner, how are the stock tunes?
Anything anyone wants to comment on blast away I am thick skinned.....
