Hello, I have searched endlessly but can't find a similar problem so I decided to ask directly.
A few years ago my 1992 mtx went from running fine to garbage overnight, like a switch. The motor has only about 90000km on it (rebuilt), turn the key it starts then dies, try again same thing, then always on the third or fourth try it starts but runs like only half a cylinder is firing. After about 3-4min the rpms go to about 4000 and then comes down slowly and as the car warms up it runs better but still not smooth and there is no power.
My mechanic (a parts changer basically) did a wet/dry compression test and said that all of the front bank was low and that the valves were not seating because of carbon buildup. However another guy who works there said that is unlikely and that maybe the timing belt skipped a tooth or something like that, I don't know what to think.
Here are the things I do know
1-No smoke or leaking fluids
2-No mixing of oil and coolant
3-No abnormal noises
4-No codes
I don't really want to take it to my local dealer but I miss driving it very much, any help would be great.
4-No codes
