Toul
I have the following codes:
511 EEC processor ROM test failure
116 Engine coolant sensor out of range
159 MAF sensor out of range
114 intake air temp sensor out of range
225 Knock sensor not tested (ignore if not pinging) - KS
A week ago I had:
543 Fuel pump secondary circuit
177 Rich
173 other cylinder bank Rich
225 Knock sensor
I concluded that the 511 was from my chip, and that the codes for Rich were caused by a bad IAT sensor sending flubbed numbers for air temp and screwing up the mixture. I replaced it with a 20 dollar IAT sensor from Advanced. Clearly my problem diid not go away, as in addition to still having a code for the IAT sensor, I now also have a code for the MAF sensor.
Does this sound like a ground problem? Was running fine up till about 2 weeks ago when it got cold if that helps at all. Also, is the coolant sensor anything I should worry about if I know there's coolant in the reservoir?
A week ago I had:
177 Rich
225 Knock sensor
