Danz13
ATX Sho Member
Hi All,
I have a 93' ATX.
I am getting codes 173 and 177 intermittently while driving. Usually after the car warms up a bit the CE light comes on and off. I have replaced the MAF a couple times, now I have a reman one, cleaned it and reset the codes between each change. I have also replaced the TPS and still getting the same codes. I have replaced the O2 sensors somewhat recently and made sure they are plugged in all the way. I have had this problem for a while but have not really driven the car much.
I have very recently replaced the plugs as well. I am hoping to get some suggestions before I replace spark wires, fuel filter, and remove and clean the fuel injectors. Thanks!
I have a 93' ATX.
